What software could I use?
And how?![]()
(I'm a "neewbie" on this and a step by step explanation would be appreciated!!!) :P
The movie is a 30 min DV NTSC taken originally from a DVD (FCP Pro could be useful?!)
Ugh, give up now! Or try a forum search . . . It's going to be really, really hard, though, and the results might be unwatchable. Definitely not for newbies. Try finding the same content in PAL format, or sticking w/ NTSC, and trying to get your player to deal with it.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
http://www.nattress.com/standardsConversion.htm
you might try this for fcp.
but if you going ntsc dvd to ntsc dv to pal, it will probably look really bad.
might not be want you want, but canopus procoder for a pc will convert the ntsc mpeg streams staright to pal mpeg without an in between. and from the reviews i've read it does a really good job at it. but it's a pc solution.
also, alot, but not all, pal tv's and pal dvd players will play ntsc discs.pants on, pants off, pants the floor. -
I know that PAL Tv and Dvd players play NTSC discs without problems...
But I have only the DV Ntsc movie on my hands.
I will try the FCP plugin you linked me...
Thanks. -
http://www.mpeg2works.2ya.com/
supposedly the new version of mpeg2works will convert formats for dvd's. anyone have it and can give a review?pants on, pants off, pants the floor. -
What about the audio/video synch issue? That's going to be the most difficult one to overcome, methinks...PAL is 25 fps, NTSC DV is 29.97 fps. Pal is 720x576 pixels (or something like that), and NTSC is 720x480. There are several factors making for likely picture distortions and/or video
ound synching problems. If you have a dvd player capable of playing NTSC, then what do you need the PAL footage for? Are you editing bits of movies into other projects? What level of quality are you trying to achieve?
It will convert input VOB ripped from DVD from NTSC > PAL or PAL > NTSC...There was a audio sync problem with first release, but I fixed that and now it works just fine...Note that VOB file MUST be re-encoded and that is time consuming process...I added bitrate choosing slider too...supposedly the new version of mpeg2works will convert formats for dvd's. anyone have it and can give a review?
This is a review from Versiontracker:
"I bought this product for the PAL to NTSC conversion, and although the output looked great, it no longer held sync with the audio, and even though I had set the bitrate higher than the source material, the resulting M2V file was less than 1/3 the size!! (Huh?!) It also completely ignored PCM audio tracks."
Note that I fixed sync problem, and yes, it works only with VOBs with AC3 audio..
Converting PAL to NTSC?
By Djehuty in forum Video ConversionReplies: 17Last Post: 3rd Sep 2011, 14:55 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 13:38 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
Converting NTSC-PAL
By B-Twien Bytes in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2009, 10:06 -
Is “Movie Clone 4 Gold” capable of converting PAL into NTSC?
By coody in forum DVD RippingReplies: 3Last Post: 5th Dec 2007, 17:39
